Cabriolet leak
(In Topic #218786)
I noticed the other day my brake lights were stuck on, then saw that my brake pedal was wet and so was the carpet in both the driver and passenger foot well. I'm unsure where the leak may be coming from; could it possibly be the bulkhead? It doesn't appear to be coming from the roof, but I won't rule it out. It was odd that nothing else was wet apart from just the brake pedal and front carpet.
Thanks in advance.
Michaela
Sent from my Pixel 2 using Tapatalk
Is the leak rain water as the heater matrix can leak which makes the carpets wet.
If the carpets are really wet you could do with taking the carpets and sound proofing out and drying everything out as it will get smelly and you don't want to rust the floor out.
Cabriolet leak
Thank you ever so much.
Door membranes is another thing to check/look at as there should be a plastic sheet behind the door cards to stop any water getting into the car as the doors are designed to let water through and out the drainages holes at the bottom of the doors.
Cabriolet leak
I appreciate you getting back to me. Thanks.
Michaela.
If you are consistently low on a/f in the expansion jug, then the Matrix is suspect, even when shut off it gets pressurized and there is a little trickle of a/f through it.
If the a/f is normal at all times it isn't the matrix but it could be a bad hose or loose hose clamp.
If you don't have a Rain Divertor over the rain tray, then water can have free access to all the holes screws and what ever.
On the doors there are 2 main drains. One is a rubber plug that is in the middle of the door Cabin side, and if that is missing and you have bad outer scrapers all water is directed from the windows into the door and the floor of your cabin.
There are 2 pucker drains on the corners of the door skin (1 each door) at the rear edge of the rear of the door, if those are plugged with debris water can build up and dribble in to your cabin via the fresh air vents and also when you close the doors briskly.
Not to many top leaks effect the floors in the front, usually the boot or rear seats/floor.
In the archive section how-to's I have a list of things about where is the water coming from.
Or click on the link in my signature there are pictures of all I speak of there.
I appreciate it.
Thanks.
Michaela
Cabriolet leak
If you decide on a new roof give me a call.
Cabriolet leak
Thanks.
Michaela.
Cabriolet leak
