Cabby glovebox removal
(In Topic #206942)
This is a usa model.
You will see the spring.
you have to force it up. Chances are it is sprung or out of the holder.
Then twist it at 90 degrees to remove it.
The Glove Box staying open issue was relatively simple to do, thanks Briano1234 for the pics.
Just the simple things getting sorted to make everything work as it should - it's almost done!!!!!!!
