Brown Windows winders!!!
(In Topic #210366)
It may be worth checking if polo or beetle/T25 ones will fit
Chairman
Try to find a Chrome set off a 80 rabbit/golf LS. I had chrome on my 81. Color don't matter on the insert as you can pop it out and Spray it the color of your choice with Vinyl Dye in a can.
Get a set of black replacements Tape the Knob off, and Spray the Arms the color of your choice with "krylon fusion paint". when dry add 2 coats of krylon fusion satin clear… should be good to go for a few years.
I had a similar issue with a 85 Cabriolet I was repairing.
one of the map pockets was butsicated beyond repair.
So I took both off, I had a good replacement but black, and sprayed them with Krylon Fusion paint and over coated with satin and they came out a pretty close match…. Doing both sides so you wouldn't miss the color differences.
Life Member
1986 Cabriolet (long resto!)
Follow us on:
Follow us on:
