Brake and hydraulic clutch reservoirs?
(In Topic #236730)
Hi, those that are running a hydraulic clutch and/or brake pedal box setups where are you locating the fluid reservoirs.I’m concerned that with the crazyquiff pedal box setup (ie master cylinders at pedal level) is there sufficient hight to place reservoirs in the scuttle panel and still have sufficient head pressure from reservoirs? Photos if possible, thanks in advance Carl.
Fluid tends to want to find its lowest point. The slave cylinders are lower, so it should be fine.
Hydraulic clutches have always been more difficult to bled than brakes.
Speak to Crazy Quiffs if they supplied it, they've always been very helpful and knowledgeable when I've been there / called.
