Bolts that hold the ignition coil on
(In Topic #230565)
Thanks buddy.
It runs for a very short while and then starts misfiring, and then misfire gets so bad that it is almost impossible to keep it running and any press on the throttle kills it.
Misfire gets so bad after approx 1 min that it sounds like it is only running on one or two cylinders, with engine rocking all over the place.
My rev counter does odd things, it drops like a stone to zero but the engine just about keeps running.
I suspected coil…..but changing that made no difference…..going to try the ignition control module next.
Yes I've had the car approx 20 years and never had a problem like this until this week.
Don't use it much during the winter and just start it up and move it every so often. Started it earlier this week, left it running for an hour and all was fine……but yesterday this problem occurred.
Going to fit a new ignition control module tomorrow and if this doesn't sort it I think I will take your advise and start a new thread.
I have had a quick look through old posts and can't find anything that gives me much to go on…..possibly think it could be the distributor hall sender….but just clutching at straws really.
Fitted a new ignition control module this afternoon and car now seems perfect…..fingers crossed!
