Blue engine block mk1
(In Topic #218232)
it has a blue block and a small plate coming out of the block which is stamped bm360
any info would be great.
regards Andy
Mars red campaign
The block itself will also have the conversion type stamped onto it, not on a tab such as you describe.
BM360 isn't a number I recognise as theirs, but that doesn't mean anything. Brian Ricketts Motorsport (BRM) evolved from GTiEngineering, have you read the number correctly?
Coincidentally if you Google BM360 it comes up as a (non OEM VW) catalogue number for the head gasket on various Golf MK1/2 + Audis.
There's plenty more info that'll answer your questions if you use the forums site search, hopefully this'll give you a starting point.
