Bleeding brakes..
(In Topic #243845)
Nothing.....nada....zilch
Any suggestions about how to resolve this? Anything else I need to check? Is their an in car way to check the master cylinder?
Am I looking at a new master cylinder?
Thanks for any help!!!!
Is your Eezibleed what e call a Power bleeder?
And yes your master cylinder can go and the main seal can allow fluid to pass into the Booster. Is there any sign of a leak between the Booster and the master?
Be warned, that you have to take the Master Cylinder down equally.. that is spin one nut then the other in even strokes like 3 on one side then 3 on the other as if you don't then you can off set your biister, and break the booster rod can dislodge from the Diaphragm and go sideways in the master.
