Big end bearing cap removal? Help?
(In Topic #209831)
Remember to check the marks so your sure that when you refit they go back on correctly.
**Cleanliness is key here! lint free rags, no dirty fingers etc etc**
Do it once and do it right! ok, we've identified the problem, lets not make it worse by guessing……… Identifying the sympton is not the same as understanding the cause
If it's that tight you may find problems under there!
Ensure the crank is at bottom dead centre.
Ensure you are making a direct strike up and through the con rod, not at an angle.
Unscrew the nuts a little and strike the studs away from the big end cap. This should push the piston up the bore and loosen the bearing cap.
I cannot stress enough that you must use the right tools here our you will do more harm than good. At the very most a copper mallet or drift, anything harder than that and you will cause irreparable damage and those components will need to be replaced.
Is the engine still in the car? I'm assuming it is? Obviously that means the lowest position for the crank will not be straight down but angled slightly towards the front of the car.
Thank you for the reply it's really helped me.
Thorhammer.com make exactly that. As for a drift, brass is very good.
You really should not be having such difficulties removing the cap though which is worrying.
Just to make sure you haven't misaligned the two parts in previous removal attempts I would leave the nuts on a good few turns, loose but not hanging off, then turn the crank 30 degrees clockwise / 60 degrees anti clockwise / 60 degrees clockwise.
Do it gently, no force should be required, and the gentle rocking motion really should seperate the two parts.
I would spin the nuts all the way to the crank, then back off a turn.
When the cap comes loose, stop and remove
Try the rocking method first.
let me know how easy it is to turn the crank?
With the head off it should turn real easy.
Either do up the nut on the side that is coming away
(Make sure the other nut is suitably loosened to allow the cap to move off) or strike that side with the aforementioned soft drift (a wooden shaft will do for this purpose) and as the cap realigns it will start to come away.
