BC coilovers
(In Topic #245617)
We have just completed the road/rally preparation of a Mk1 GTi that came with some BC BR series coilovers set very low. We have subsequently reset to std ride height and the resulting ride is probably the most compliant Golf i have driven. As i recall the BC factory advice for spring rate on the Golf is 5kg/2.7mm. If you are doing primarily track work then a stiffer spring rate may be advisable
