bad starting when hot
(In Topic #203694)
as above
The hot engine bay and low fuel pressure could bemaking the fuel boil in the lines.
Try priming the pump several times before cranking by switching the ignition on and off You should hear the pump prime. if it doesn't then you may have an after market pump relay or a faulty one. The other way is just to flick the engine crank enough to make it see a signal at the dizzy. that should break the pump into life momentarily and rebuild pressure.. See if that improves it.
Chairman
It was eventually trace to the metering head. Once changed it never did it again (fingers crossed).
Lee
2001 Zafira 1.8
2001 Zafira 1.8
thanks every one.
I had this issue and new accumulator sorted it
lhasa green 83 gti tintop MOT passed Aug '14 after nearly 12 years!
swb transporter 6.1 Highline 150
