Backfire when hot
So im at a loss with what to try next, my cars a 83 1300 with weber 34 ich.
 Ive replaced ht leads plugs coil dizzy cap and coil, it has electronic ignition
 I booked it in at a classic garage and they set the carb up and it runs amazing ticks over lovely and starts easy, they also checked timing and said it fine.
 the issue is after 20 min of  faultless driving itll start bogging out when i push the acelerator pedal, and then start backfiring and jerking and cut out, it will re start run rough as anything bog and backfir but i can manage to limp it home, first thought was probly too rich when hot but ive changed the main jet down from 125 down to 120 and turned the mixture screw to 1.5 turns out. The fan kicks in and temp gauge only ever gets up to below half way.
Any ideas?
