Anyone know what this connector is for?
(In Topic #218306)
Loose under fuse box
Found this hanging down while fitting my 292 relay this morning.
Anyone got any idea what its for or where it should go?
Wire is red/black stripe single spade connector
Current rides:
There are multiple loose connections on the back of the fuse panel, that appears to be one it is probably not used and is the power point for an optional item that isn't installed on your ride.
The Bentley/Haynes would show it… Rubjohnny can probably tell you exactly.
Briano1234
I wasnt aware of spare connections behind the fuse box at all
Current rides:
If everything works then just leave it well alone
Central Electric 1
Otherwise drive yourself crazy going through this list.
A quick look says it might be the switch for the A/C
Ian
Central Electric 1
Ian
Well my fan doesnt . . .
Wow! Thats quite a list.
Cheers Briano1234 and borednow you pair always seem to have the answers and come to my rescue whether its good or bad news one day I'll see you both at an annual gathering and thank you in person
I dont doubt chortle expertise will come into play with roof based questioning before too long either
Current rides:
Roof based question?
Did I miss it?
Did I miss it?
Did I miss it?
mark1gls said
Did I miss it?
Yes I do believe it was in another thread, as you were probably tooooooo busy installing a new hood to see it.
just to answer this, its most likely the spare cranking live feed on plug C. used on kjet and digifant injection amongst others
