Any guides on here - to replace heater matrix on 91 cabby
(In Topic #209811)
Tony
A/C equipped is here.
http://www.driversfound.com/scirocco/techtips/body/heatercore/
My addition to it is to cover the above cut out after with a Piece of Plastic that you trim to fit, and affix with 3 Trim Screws 1/4 inch in length.
One big hint is a two pairs of Hose Pinch Pliers, to limit the coolant drain from the inside to only the core. You place them on the engine side of the firewall. I also suggest that you replace both heater hoses at that time so you don't have to worry about them in the future.
Hope this helps.
Lee
2001 Zafira 1.8
2001 Zafira 1.8
It should look something like this if its a later S2
Do it once and do it right! ok, we've identified the problem, lets not make it worse by guessing……… Identifying the sympton is not the same as understanding the cause
As previously mentioned its tight for access but work in the engine bay first and get the hoses disconnected (if she hasn't had a coolant change in the last two years then do that job at the same time)
I use a low pressure airline and apply pressure to one hose to the matrix, this helps drain out the coolant so she will not leak as much inside the car.
Then remove the clips from inside - use rags inside because some will spill out no matter how well you blow it clear.
Pull off the cover, withdraw the matrix
carpet and centre console are already out.. as I am trying to find another leak through the bulkhead
I have a new heater matrix from vw heritage, but don't have new hoses.
I assume I need 2 of these hoses ( wow £13 each!, the matrix was only £20)
http://www.ebay.co.uk/itm/MK1-GOLF-Hose-Bulkhead-to-Heater-Matrix-Mk1-Golf-Jetta-Scirocco-/391356267213?hash=item5b1ea6bacd:g:AmkAAOSwd0BV1MbN
is the cover easy to get off?
1 x
http://www.classic-vw.co.uk/heater-pipe-to-engine-hose-joiner-5317-p.asp
is always helpful, especially if the original is a metal one!
The cover is easy, just push in the little tabs to release
Will make a start from the inside tomorrow
Briano1234 said
As you pull the hoses through the firewall have a bucket handi, then if you can blow air in to a hose and catch the dribble in a bucket on the other side.
I am not to fussed about the water
As vw had managed to put the interior clips round the back of the pipe I couldn't get to them with my hose pliers so I just cut them off too. Matrix is out
Do yourself a favor. Replace that plastic butt-to-butt connector. Go yo a hardare store and get a Brass Barbed Hose repair. That plastic piece is old, and weakened. It is a time bomb on your ride that will fail you.
5/8 inch hose mender.
I had one break on me..... I was stuck on the Interstate until I called a Taxi to pick me up.. run me to the Closest Hardware store, and a Gallon of fluid later.... (4 hours, and a 50 dollar cab ride, plus the cost of the Gallon of water, A/F and mender).
I have a How I hate plastic parts thread....
http://forums.vwvortex.com/editpost.php?p=85167922&do=editpost
Where I have replaced all the plastic frigging parts with Metal.
(yes the 92's Plastic outlet flanges for Digifant.)
And Beefing up your heater Valve to prevent failure.
http://volkswagenownersclub.com/vw/showthread.php/91714-Those-Plastic-Heater-Valves.....?p=644178#post644178
