Aerial cable routing
(In Topic #242197)
I've taken lower n/s parcel shelf out to get hand up under screen but can't see it or feel it.
Where does it go ??? Spent an hour half doing pointless things 😡
It is probably curling up near the fuse panel.
it should run over the fuse panel to the side of the heater box then up and over the back side of the heater controls.
Just be sure that you include a drip stop loop from the outer fender to the antenna base, failure to do this will give water a ingress right above your fuse panel.
Found an alternative route and sorted it in end
