83golfgx
(In Topic #244631)
Will an inlet manifold and carberettor of a mk2 golf 1.8 fit my 1.5 mk1??
This is an old post of mine…It may not help but it could?
This was not showing for 1983 car but wondered if it's the same?
Weber with kit 15290993 for a 1.5ltr(1977-1979 year) or a 1.6ltr
This kit includes the following for your engine:
73801150-150
77201165-165
61440211-F6
74409050-50
76407050-50
79701040-50
79531175-175
6.25+or-0.25%
Hope that helps.Contact Weber for supplies.
Off golf.
No interest so gave it away.
See Brendan at mk1 do.
I doubt the two cylinder heads are identical so neither will the inlet manifold be. Something about extra water passage may be….
The weber kit used an adaptor to the vw rubber gasket damper mount. Get the adapter to suit the inlet manifold you have. Or have an engineering firm make it in alloy.
The choke sizes may be OK but mains /idle jets will be too large. See the previous companies for the parts.
As it has been decades since fitting these kits I've forgotten and thrown away a lot.
I could ask someone at the mk1 show for pics
or better still wander around there for a car/owner with the conversion.
