1991 CLIPPER 1.8 PETROL TANK REPLACEMENT
(In Topic #222127)
I have decided to replace the petrol tank and filler pipe after discovering rust specks in the filters (car was off the road for some 10 years -whereabouts unknown).
Looking for advice as to whether the petrol tank should have a 40 litre or a 52 litre capacity.
I also note that the back axle needs to be dropped (a bit a least ) to extract and replace the tank. Has anyone got a "how to" for this job. I'm sort of hesitant to tackle it in my home garage if specialist gear is required.
Any advice gratefully received
den
Catch 22. When the axle comes off expect the worse for the body mounts as they may need welding. I left the shocks loose but in place just in case. If so you may need the axle back on to move it. It's a bonus if they dont need doing.
From the fuel sender soft rubber lines to hard fuel lines I colour code mark them to save confusion and replace one at a time.
84.5 and newer you have a 13 gallon tank and a space saver spare tire. … the spare tire size is the key to the change.
Spray all Axle bolts and nuts with PB=Blaster for a few days prior. Then use a 6pt socket and a air impact or electric impact wrench only…. If you use a breaker bar you will torsion shear the axle mounts for sure… With a impact you may shear them but it is a lot less likely.
