1989 golf gti cbrio
(In Topic #242494)
rough running
I am looking for advice on my K-jetronic fuel system.
I am attempting to put my project car back on the road after many years in storage.
I have fitted a new fuel tank, lift pump, high pressure fuel pump, replaced the accumulator, new fuel filter, new fuel lines.
I have also fitted new Ht leads and distributor cap as well s new spark plugs, but the car still runs rough and does not accelerate as it should when being driven on a test run.
any suggestions would be appreciated.
Many thanks,
Jim
I have not checked for vacum issues other than the fuel tank where it draws air in when I remove the filler cap which I believe will be a blocked filter near the filler neck, so I have been running the car with the filler cap off.
where do you suggest that i check for vacum faults?
many thanks,
Jim.
I have an issue with the red warning light that sits inside the temperature gauge on my 1989 Golf cabrio gti.
The warning light keeps flashing when the car is running.
I have fitted a new radiator, new water pump and thermostat and all new hoses except the two heater hoses.
Any suggestions?
regards,
Jim.
1989 golf gti cbrio
Sent from my AC2003 using Tapatalk
regards,
jim.
Kind regards,
Jim.
