1989 clipper fuse box diagram wanted
(In Topic #223262)
fuse box woes
i have been offered a G reg clipper 1.8 carb model Ex engine code i believe its been off the road for around 4 years i went to look at it and noticed the number 19 relay on the floor
it did start and run before it was parked up for the long period - i have a pic of the fuse box and what fuses and relays were in place when i got there and i want to compare them to a running model
when i turn the key i get no dash lights ( is there an in tank pump i should here priming when i flick the key ) i do get a spark at the plugs but i don't see any fuel flow in either of the 2 clear filters it looks like there is a lift pump on the front of the block
i have no idea what the wire going to the number 11 space in the fuse box is for and neither does the owner
i know the car needs a new roof , new interior , and carpets and a better dash , so ideally i want to here it run before i pay the price being asked for the car
any help would be appreciated
Last edit: by nme224
its not a problem just a challenge ?
From Cabby-info.com
