1985 1.6 auto... Oil sump change.
(In Topic #208631)
Is it a straight forward job or does the auto gear box need to be dropped ? I've just had shoulder surgery so I need to find out how it's done.
B505 YYE is the Reg. I'm also having trouble finding the correct sump if you guys could help!
Thanks guys
I had a bit of work done to the body last in the summer and the lad said I need a transmission gasket and oil sump gasket, so the sump may be ok., I'm not 100% sure what the transmission gasket looks like.
any ideas ?
sump there are 2 version the mk1 and early mk2 version is shallower then theres a later cab/rocco and mk2 which is a bit bigger. both will fit fine
While its off IF you have starter problems by chance?Then fit a new starter now! as its the only way you can change it, and, there's two types for different widths of starter ring.
Good luck.
