1984 GTi Cabrio Hazard Switch problem
(In Topic #208033)
Indicators work - but hazards don't
I'm going to ask this site's GTi gurus what they think is up with my daily driver as it has me flummoxed!
Roy
Same Relay/flasher
Same Wiring to the lamps.
The only differences are,, the turn switch which isolates it to the left or right side.
The fuses for each low number for the hazards, high number for the turns.
The hazard switch is controls the turns as well as the hazards.
The hazard has 2 sides, 4way when flipped on, and turns when off.
The hazard has 2 un-insulated connectors attached to it.
If they short out they usually take out the high number fuse. It is a good thing to use some heat shrink on the bare connectors.
If the hazard switch goes out, then yes half of it can be bad, and your turns work. I suppose it can effect either circuit depending on which side goes out.
Photobucket is having issues and I can't get the photo up to paste.
If the Turns work, then it is likely the hazard switch.
After my mishap, with the springs flying off in all directions, I'm not sure the indicators now work at all!
Kind regards,
Roy
I fear I damaged it; despite looking around at the usual suspects online, I can't see one for sale anywhere - and haven'y yet found it in your amazingly extensive range of wiring diagrams.
I guess it's a dealer-only part, huh? Or maybe get one from a dismantler.
part number is 171972999 try Mark at http://www.classic-vw.co.uk, he should be able to get you one. he stocks terminals too if you need those, plus can prob get you a new switch too if you cant find all the pieces
failing that VW classic parts can supply one for you:
https://www.vwheritage.com/vw_act_vwclassicParts.search.htm?classicSearchText=171972999
Roy
