16V KR Cuts out when hot in stop and go traffic
(In Topic #203242)
I am having an issue that when the car is just over halfway on the water temperature it cuts out. This happens when you have been in start/stop traffic. Fan cuts in but once it has cut out a few times if you leave it 10 minutes it will start fine. In normal moving traffic temperature sat half way with no issues.
It sounds as if the fuel is struggling to get through when it gets to this point, misfires and then cuts out, sometime wont start again straightaway
If anyone could help, give me an idea what may cause this would be a great help
Many Thanks Kieran
http://www.vwgolfmk2.co.uk/forum/viewtopic.php?f=37&t=25972
what fuel setup do you have on it? later cab with lift pump, swirl pot then main pump or early with mk1 gti fuel tank fed direct to the main pump?
this thread is worth a look anyway:
View topic: Fuel Tank cleaning *HowTo* clear that blockage - The Mk1 Golf Owners Club
Campaign Mk 1 Black
16v Mk2 Red (decsd )
They get so toasty that the solder on the relay connections internally open. Stopping the car.
Once they cool off they reconnect (but Cold soldered) and you drive on down the road, till it happens again…. Rinse repeat, rinse…
The Durability of the newer relays "being made in China" folks usually carry 2 spares in the boot bag of goodies.
Similar to me carrying around Water outlets and the 10mm socket to replace them on my Cabbies till I got metal replacements.
the 17/18 x-relay is a better fit, or a mk4 golf SAI 100 relay
First of all I need to fix my new problem, Had a tinker with car last night, found a couple of loose vacuum pipes and cleaned all wiring terminal as per general health instruction, then run car over the 3/4 marks and didn't cut out as before, however one of the coolant pipes has now decided to give in as I had a pin hole and water spraying. I have ordered new pipe today so will let you know how I get on, the joys
Cheers all
Thanks for all your help guys
on mine it ran at 3/4 when I first built it and this was due to me fitting a carb 1.8 single core rad, once I binned it and fitted a proper 1.8 8v GTI double core rad it dropped back to where it should be
Many thanks
