1.8 gti dx lumpy start and stall.
(In Topic #229013)
Lumpy only just about runs when foot on accelerator.
Sat and Ticked over for a few mins and Then it just died and on trying to restart it just turns over and over unless you give and hold a bit of accelerator pedal and then it just ticks over very very lumpy. As soon as off the gas it dies.
AA Man didn't have a clue.
All reasonably new plugs and leads and dizzy.(2years)
Spark good, fuel pump sound normal, cold start not firing when checked but engine was warm from initial tick over.
Air flow plate moving freely.
A lot of fuel when I removed the spark plug but could be as I was turning it over and pressing accelerator a lot. ?
Any ideas as to next move? I know it's a bit vague but someone may have experienced similar?
Any help appreciated
Check fuel tank for corrosion, also fuel filter incase of blockage.
If ok, then I would carry out a fuel pressure test as it could be the Warm Up Regulator. The brown Haynes manual has detailed instructions on how to carry out the test.
I had checked and There's a fair bit of corrosion around the solder on the circuit board in the relay. I've got a new one in order. £45quid!!
Thanks!
Worth getting one of these. I bought this from eBay. Was worth the investment as it helped me resolve a lot of issues I had with the CIS.
You hook the guage between the fuel metering head and the WUR fuel line.
If the fuel pressure is too high during cold start up, that's your problem.
During cold start, the fuel pressure should be low as the warm up regulator lowers the fuel pressure and the auxillary air valve is open to allow additional suction to lift the air flow plate, then you get a rich mixture. As the car warms up the bimetallic plates in both the AAR and WUR heat up and close the valves and the car starts to run leaner and you notice drop in revs.
With my car, both the WUR and Metering Head were suspect after I carried out the tests, so I had them overhauled by KMI Injection UK. They are expensive, but they are absolute professionals and you can't fault their work.
