1.8 EX petrol break down no spark PLEASE HELP ME?!
(In Topic #205582)
Last edit: by MK1CabbyWhite
MK1CabbyWhite said
I had problems with fuel starvation before, I couldn't get my sender unit loose before it was stuck so I disconnected all the fuel lines and blew them out and it fixed the issue, it used to cut out after a few minutes and take a few minutes to get fuel again, since then I've replaced the filler neck & fuel filter and the other night I had been driving for around 40 miles then it bogged down and cut out 2 minutes from my house! Was on a slight hill, then started up again after a couple of minutes, with my new filler neck this hose back to the top doesn't seem to fit on, could this cause an airlock/cutting out??![]()
Fix that pipe to your fuel filler neck ASAP or water and dirt will get into your fuel system.
To make it easier it fit trim the end where is is squashed and get some boiling water in a cup place the end of the hose into the water and wait a few minutes as this should soften the hose so it slides on easy, don't forget to fit a jubilee clip first.
I'm doing an oil service and a few bits on it tonight so hopefully can get it on properly then, cheers for the tip!mark1gls said
Got plenty done tonight at work, fitted proper connector to broken earth wire, oil service (all genuine parts & castrol oil), tightening my aux belt after 100 miles on a new one & checked my ignition timing, got that pipe sorted too, cut a couple of slits in the end & a bit of bmw silicone spray (AMAZING stuff, I call it magic spray…) and it poped straight on there, with a nice bmw jubilee clip to finish!mark1gls said
A little smear of grease on the filler neck may also help. :-)
"The other day I was cruising along as usual coming onto one of my motorways, which was very busy with inferior cars. First off, I couldn't believe that the volume of traffic DIDN'T slow down for me AT ALL as I came off the
slip road! I had to squeeze into a barely big enough gap between two cars in order to get onto my motorway! (The driver of the car behind me did realise his mistake though and honked an apology to me with a long blast of his horn.) Unbelievably, I had to do the same again before I could get to the BMWlane. (Why do underlings use this lane? Surely everyone knows it is for BMW drivers only?)
Anyway, once I was in the BMW lane and posing along at 110mph enjoying
the adulation that the inferior car drivers were giving me, I noticed an inferior car ahead of me which was not only in the BMW lane of my motorway, but was driving at a ridiculous 70 mph! Naturally, I got to within a 20 foot or so of his rear bumper and flashed my headlights to remind him he shouldn't be in the BMW lane of my motorway and to get out of my way. Of course, once he realised it was a BMW behind him, he did just that, but I could hardly believe it when he pulled straight back out behind me! He also tried to keep up with me and when he realised I would out-run him, he put on some blue lights in his front grill and urged me to get onto the hard shoulder so that he could congratulate me on my excellent car.
Needless to say, I was eager to oblige and when we had stopped, the man gave me a piece of paper confirming what I already knew - that my car goes fast!
Apparently he wants everyone to know what a superior car I have, so I had to take my driver's licence to a Police Station to be sent away to have some points put on! (They're not free points either - they're £20 each and I was only allowed 3). But the man at the Police Station said that because I drive a BMW, it won't be much longer before I earn the full 12 points, and then I won't even NEED a driving license, so they will take it off me!
See, now that's the sort of respect you get when you buy and drive a BMW!"
