1.6 GLI stops after 10 minutes running
(In Topic #237870)
The fuel pump ran all the time but the strobe light stopped when the engine died. Could a faulty fuel pump relay be the cause? Which relay do I need to fit to this model and is that straight into the fusebox or still into the extended wiring?
At the moment the relay activates as soon as the key is in ignition on position. It doesn't come on to prime and then go off. We tried a relay from a Mk2 that did that but the car didn't want to start. I'd like to change the relay just because it is suspect but that may not be the cause of the cutting out.
So Q1: which relay should I fit and what will it do given the car already has the 'retrofit' wiring?
Q2 For the ignition to break down after 10 minutes seems like something overheating. We've tried another coil, another CDI and new plugs leads and distributor cap. Any other ideas? Could it be the ignition switch or another relay at fault?
does the fuel pump run constant with ignition or only when cranking/running
The pump runs constantly with the key in ignition on position. It doesn't prime and then stop. But it's an Opel relay when we check the number.rubjonny said
if that fuel relay is a correct kjet/rev counter triggered type, then you could either have a faulty relay killing fuel then engine, or a fault in the ignition system killing spark which will then kill the relaydoes the fuel pump run constant with ignition or only when cranking/running
Which relay should we be looking to fit now and should it go into the dealer retro-fit extension ro should we remove that and fit the replacement relay straight to the fuse board?
I've read that the original relays with the fuse on top were unreliable; which is what the retrofit extension was supposed to cure. Are later versions still unreliable?
though you'll still want the correct VW unit ASAP as currently your fuel circuit isnt even fused unless whoever fitted the wrong relay put one inline. the original VW relay has a fuse in the end of it… part number is 321906059C or KAE part number 3.300.100
https://www.ebay.co.uk/itm/325096611643
if it turns out not to be fuel relay look at ignition switch, wiring from it, possible alarm/immobiliser issue or possibly coil though those are pretty bomb proof if original bosch unit. If it has electronic ignition then you an also look at the distributor hall sensor or the ignition module. if it is factory electronic ignition then you can use a mk2 golf ignition module they plug right in
rubjonny said
ok, assuming the open relay is same layout as VW you can swap it for a vw '53' or any standard 4 terminal relay which will bring fuel pump on with ignition (for testing purposes) if the car still cuts out then its not your fuel relay.
Thanks Jonny, we'll sort the relay first. We've substituted the ignition module and the coil from a MK2 and the fault is still present. Hall sensor is a good shout, as is ignition switch. It's really annoying as it starts fine from cold but we are reasonably sure that it is igntion and not fuel supply.
If we get the relay you suggest should it be plugged into the main fuse board or into the remote assembly or doesn't it matter?
From my experience the fewer connectors usually the better.
