​I need help with some wires.
(In Topic #219784)
I'm changing the radio for an original one, I found these 3 wires that were cut.
Could you tell me where to connect them or what are they used for?
In the second photo, both wires from the red cover were also cut.
Where do they go?
Thank you so much.
Where do they go?
Thank you so much.
www.cabby-info.com has a diagram on which wires go were for radios installs.
Red was usually used for switched wiring, that is B+12V switched.
Yellow was the color for the Keep Alive (preset channels clock)
Blue was for the external powered antenna.
Brown red was used in the speakers on a non-active system, and the only white/yellow was for the speed sensor to increase the volume as in top up or down and road noise. Plain white could be either a speaker pair or another +12V wire to run the Antenna
You have some wire chasing to do I am afraid, but I will tell you to look at the back of the radio to see what you need…She has the diagrams there for those as well. It isn't uncommon to tie in to the Defroster (demister) for +12V Switched power on new radio installations.
see:
http://www.cabby-info.com/Files/AudioSystem.pdf
see:
Thanks for your answer
Briano1234
Reading the car's intruction manual I have seen that the brown/red is positive after contact.
Anybody nows, Where do they go both wires from the red cover of the rear fog lamp?
They are positive and negative direct? or they are for a interior lamp button?
If you follow the red wires back, hopefully you will see where they were jointed and then find the correct colours for them.
Fog Light
Green Yellow - Fog Light Relay Output
Other than that it shold have an eath (normally brown) a live (normally red) and a input from the head light switch which is probably grey and blue
Have a look through this lot
Central Electric 1
Ian
Fog Light
Central Electric 1
Ian
see:
you sir are a gent!!!
fitted my VDO's Thurs/Fri evening and ive lost the front left right speaker connection somewhere along the line, think its when i was messing with fuse box as i can see the speaker connection is fixed to the car around that area!
now have to trace trace trace and find the problem, this link will help massively!
Euro stereo wiring:
red - live
brown - earth
blue/grey - illumination
yellow/white - speed signal
brown/red - key-in-ignition live
wiring to your heated screen switch is not original, I bet its been re-purposed for something else in the past, kill switch maybe.
it should have:
black/yellow - x-relay power
green/white - screen power
grey/blue - illumination
brown - earth
on your radio wiring, I can see a thick white/yellow as well, this might be from the fog switch (front fogs) so thats worth a check…
red - live
brown - earth
it should have:
brown - earth
I boght my car three weeks ago and this wires have it cutted.
I don't have problem to connect the radio.
The problem is with the wires that appear in photos.
With your help and trying I already know what is the brown-red that is positive after the ignition key. The red with red fog button cover is direct positive and turns on the light of the switch.
The yellow-white comment that it is for the signal to the radio of the speed but there are two equal cables (one thinner and one thicker, as you can see in the photo and both are spliced).
I just need to know where is the black wire with red switch cover (second photo).
those switch wires are all non-original, dig into the dash wiring and see if you can find the original wires with the colours I mention
Also have a look at the CE1 section in here:
https://clubgti.com/forums/index.php?threads/fusebox-faq.219775/
