2lt TSR engine needs a rebuild-by who??
(In Topic #218726)
Hi, This is for my Mk2 Gti 8v -so hope you don't mind me asking here..
Its a 'Brands Hatch' TSR conversion using a Passat crank, Pack C head and 285 Piper cams that I have had for about 10years, and its never been any touble, was always fantastic and gives around 150 ponies.
Unfortunately, recently, the oil pipe pick was getting blocked and I did not realise until it was (briefly) starved of oil at low revs.
I cleaned out sump (no metal pieces) and unblocked guase and it runs 'ok' but vibrates which it never did before! The oil warning light goes out and stays out but I reckon it has picked up a bit on the shells or bore (it never siezed but 'tightened up' a bit so I killed it.)
TSR has been through several owners and when I had this engine built though the guy who built it (Tom) was excellent , there were problems which related to me not bieng particularily confident about them thereafter. It could be they are back and fine now(?)
BUT I need to know a few proper engine rebuilders who are experienced in non original engines and WHO YOU CAN RECOMMEND.
So, please let me know who youi would trust!
I am based in Norfolk though that does not have to be an issue as would travel to the right place.
Thanks.
Marcus.
Thanks.
Marcus.
It has literally come to mind there is a place on the A140 just after diss (Ipswich side) called scholar engines might be worth a call or email.
http://www.scholarengines.co.uk
