Why doesn't my van like the cold
(In Topic #127169)
Now it's getting colder in the mornings my van don't like starting it takes a few times at heating glow plugs up before it will start and when it does start it smokes really bad but after a few seconds it stops smoking and runs fine
Thanks for it help
Luke
<a><img></a>
I no longer have the Mk1!! I now whizz round in a Black 1990 3dr Mk2 GTi 8v but the roof doesn't fold back when the sun shines
Is the a warm up type thing or choke on a diesel
I will try bert aswell thanks
Cheers Luke
<a><img></a>
Anyway, sounds exactly like a glow plug issue, either they're not firing, or the temp sensor they're linked to is faulty, or the glowplug timer or ECU etc etc. Best to find a Vauxhall Movano forum and ask there.
<a><img></a>
SOOOO sorry
booze and boredom, the greatest mix
I used to have a Merc people carrier and had a problem with it starting in a morning Autumn / Winter, once warm ok but first thing an absolute pig and even had to jump start it a few times. Turned out it was carboned up etc, needed stripping, de-carboning, new injectors, glow plugs etc. Set me back £1,500 8O 8O Ran like new afterwards though :mrgreen:
Assuming its an old school indirect injection diesel and not a new direct injection festooned with electronics, 99 times out of 100 poor starting when cold is duff heater plugs (or poss the relay that runs them).
The only problem being that old fashioned diesels where outlawed when new Euro4 (3?) emission controls came in about 10 years ago so you may have a newer motor that needs a main stealer computer to tell you its going to cost £££££.
i work on them day in and out, prone to glowplug problems in the newer models. they work on a circuit, so if the block/engine temp is high enough they will not b needed in staring up, but first thing in the moning when its cold, they will be needed, thus taking a while to heat up and your van to fire.
it'll smoke till its hot enough.
take they plugs out (bit of a chore if its a od fashioned 2.5 or 2.8 naturally aspirated as they are in the front of the head and quite iddl to get at.
the newer models are easier to get at, but it you snap one off in the head, you'll never get the stem out.
here for a good time, not a long time
van
hth and if you want any more help, let me know.
dan
If I leave it till mid day and start it it's fine would this still be glow plugs
Thankyou Luke
<a><img></a>
i can find the part number and try and get a photo of what you need.
dan
Luke
<a><img></a>
if i remember, there is a bit of pipework with a sensor type to the top right of the airbox coming from the inlet manifold, in there is the preheat system. think its a main dealer part only, but i can find that out too and a price. (we use renault parts for all our movano's.)
give me a couple of days to get a look and a picture.
dan
<a><img></a>
glowplug
i haven;t got pic yet, but will do today,
the renault part numer is 77 01 040 221 and its retail price is £92.07
i'll get a pic today of the manifold with the plug it.
dan
van
dan
