Stupid question please don't laugh
(In Topic #85202)
MK1 GTI 1983 (love of my life)
Mazda MX3 1.8 V6 ( Daily Drive)
I think this refers to engine capacity or size. The cyliders in total could hold a total of 1000cc or 1 litre of fuel/air mix. Only a tiny amount of fuel and air is used to cause a mini explosion.
I think that's the theory. I'm not a tech.
it's dumber not to ask
con
Re: Stupid question please don't laugh
richyrich said
When they say an engine is a litre what does this mean? is it the capacity of all cylinders? Would this not mean than in a 1 litre you would use one litre of fuel every revolution? I know this not to be the case but could someone explain to me how they take this measurement. sorry if i'm being dumb
right. i'm going to pretend i never read that, but instead, you are asking how they work out cubic capacity. (cc)
it's basicaly the capacity of the cylinders. e.g. 81mm bore x 86.4mm stroke x 4 (cylinders) = 1781cc (cubic centipedes)
that didn't explain anything, did it?
then this mix explodes because of sparks from plug.
this explosion forces the pistion back driving cranks eventually turning wheels. Each cylinder sucks in air, petrol, compresses, fires, pushes out exhaust fumes in a cycle see here
http://en.wikipedia.org/wiki/Engine
there's a diagram on the right
85 Polo squareback
MK1 MX5
MK1 MX5
Bert said
centipedes are those bugs with 100 legs right?
Bert
do NOT EVER go shoe shopping with one of those!
It's all going to depend on carbs/fuel injection + fuel air mix isn't it
suck squeeze bang blow….in the order of 1-3-4-2(cylinders) only one cylinder is banging at a time but this happens so close together……….
DAM it I give up
But Dont think you could work out what your after and get a reliable answer……..lots of factors …..give variables…..how hot or cold engine is outside temp……..gradients……ground resistance(from snow or ice) and so on……:dontknow:
LMAO now as Iv just read the above makes no sense to me at all so think you should all read and laugh at my expense
Always do sober what you said you'd do drunk….that'll teach you to shut up
Obviously, turbocharging or supercharging forces the air (or air/fuel) mix in, so it can be at higher than atmospheric pressure.
When people talk about tuning techniques such as port/polish, bigger throttle body, air induction kit, performance air filter, etc, the aim is to more efficiently be able to take in the gases (flow them better), so it gets closer to atmospheric pressue (normally aspirated, not turbo) at full throttle.
Life Member
You would have to conduct an experiment along the lines of….
Fill a car with a measured amount of fuel.
Let the engine run at a CONSTANT rpm until fuel runs out.
By multiplying the rpm value by the total number of munutes the engine ran for, you would have total engine revolutions.
Divide you measured amount of fuel by the total revolutions and you would get volume of fuel used per revolution.
The results would vary greatly depending on what RPM you sat at, the condition of the air you are taking in to the engine etc.
During normal driving conditions, you of course vary the revs constantly, so the results of this test would be completely meaningless!!!
If you want to get more miles from your fiver while driving to work in the snow, select a high gear (3rd or 4th) instead of low gears (1st and 2nd) and stop spinning the wheels and revving the engine!
My Build Thread
I would do a full tank 35 Litres after about 400km doing 128kph at 4000rpm (converting roughly to metric, and running a bit rich)
Therefore…..(scribble scribble :scratch: ……tappety tap on calculator
=0.047 milli-litres of fuel per engine revolution.
1983 Lhasa Green GTI
1.2 litres / 4 = 300cc per cylinder
AFR is approx 15:1, so (300/16) = 18.75cc of fuel, and 281.25cc air per cylinder per power stroke.
18.75 /2 (as four stroke) = 9.375cc fuel per power stroke per cylinder
9.375 * 4 cylinders = 37.5cc per engine rev
As paul_c says, this will only occur under full throttle - anything less than that will give you less airflow, and therefore less fuel flow. As a rough guide, 1/2 throttle should give you half fuel flow rate, 1/4 will give you 1/4 fuel rate, etc…
HTH
Rich
