Squeakin!
(In Topic #73580)
Squeakin!
Anyone else have a squeaky dashborad?! Its driving me nuts, pretty much only on the drivers side at the top. i think its the window rubbers it rubs on. Any ideas how to solve it?
Lewis
Lewis
Mine squeeks like a bandit also. I have looked into the problem and it mostly seems to be down to the lower dash mounting bolt/bracket to the lower a-post…although when I got it sorted, I'm down to about 3 mice and not the previous 30 squeeking away.
I've got some anti-squeek tape to solve this when I get the dash out. You can get them in little pads or as a tape on a role - car manufacturers use them all the time.
Hope this helps.
Hope this helps.
'83 Helios Campaign Gti
On nearly every dash i've taken out the two brackets holding the instrument cluster have come loose - particularly the screws that go into the top of the dash - they work loose and drop out.
Also many people dont seem to put all the screws back one they have a dash or under trays out :wink:
I had the dash out of mine not so long ago, and when i put it back placed foam between the dash and every other surface it came in contact with, and it quitened it down a lot. Quite difficult to do though.
1983 White cabriolet GTi
