Scuttle Panel advice on a clipper cab needed!
Is the plastic scuttle cover on a cab supposed to cover the lenth of the scuttle etc?
Or just the middle section as i have water coming in from the drivers side of the scuttle and this is not covered etc but dont want to buy another if its not gonna cover the whole lot to cure the prob!
As i dont know if mines been cut or supposed to only cover the middle section?
Any info would be great Thanks  :wink:  :dontknow:
Keep the Faith!
Drive Safe Cruise Hard!
Cornwall
Pip
Cruising & Riding with a big smile!
VW Mk1 Cab,VWT4,Lambretta GP,Vespa T5
it just covers the middle section, take the cover off, and clean the tray area out.  Make sure the drainage holes are clear of leaves too.  you could also remove the cover of the heater blower unit and make sure its clean there too, bit of silicone sealer around the area might help
chris
Chris
ta
cheers for that! didnt want to waste money on a new one then find its the same!
Thangs again and il try the advice  :wink:
Keep the Faith!
Cornwall
Pip
