Now *I* need cheering up
(In Topic #87432)
Now, the car idles between 15 and 20 when warm, and still dies when cold - possibly worse than it did before the injector seizing problem.
On top of that, the stereo isn't working (I haven't checked the fuse yet), and somewhere between the tow truck, the first garage and the second garage, they've rebroken my glovebox hinges.
My car had been so reliable until the fusebox went a few months ago. I'm getting really sick of not having my car in working order. Someone make me feel better, please.
<img src="http://i35.photobucket.com/albums/d186/Missmoopants/Golfskissing2.jpg" border="0" alt="Two lovely Golfs">
Oi vous des singes votre pays a ?t? envahi ainsi beaucoup de fois que vous devriez au moins avoir acquis ? ce jour les qualifications pour fixer une voiture allemande ! triez-le imm?diatement ou la tri couleur tombera encore :wink:
basicly it says…. oi you monkeys, fix my car or France will fall !! again :wink:
I'd then adjust the mixture (3mm allen key just next to the metering head) and finally the idle, which is a 7mm bolt on the back of the throttle body.
HTH
Rich
this should be a better approach :wink:
Pouvez vous veuillez v?rifier la pipe de remplisseur de carburant au cas o? elle serait rouill?e, si c'est peut toi la remplacer et v?rifier ?galement ? l'int?rieur du r?servoir d'essence par la couverture d'inspection sous le si?ge pour voir si la salet? est entr?e dans le r?servoir, peut ?galement aider ? mettre un nouveau filtre d'essence sur la voiture pour voir si ce aide le probl?me courant
basic translation is….
Please can you check the fuel filler pipe in case it is rusty, if it is can you replace it and also check inside the petrol tank through the inspection cover under the seat to see if dirt has gone into the tank, may also help to put a new fuel filter on the car to see if that helps the running problem
Wanted: dubboy who can teach me about mechanic stuff and is willing to be my bee-atch here in France. Mountain biking and swimming in Lake Annecy thrown in as well!
Topoftherange, thanks for that: the fuel filler pipe was replaced late last year so it's a likely problem, as it was rusting out before that. I reckon I'll steer clear of referring to the pipe as "pipe" (hose is better, but I've forgotten the French word for it - it's really hard to say …"breuyeu" or something`). "Pipe" has a very rude meaning and as a girl, I definitetly don't want to be saying that to a mechanic….although I suppose I could save a lot of money if I offer that "service"…
Sounds to me like it might be the warm up reg (assuming Mk1 cabs have these like the later tintops did?). Again someone checking the fuel pressure readings at cold and as the car warms up should be able to see if this is the issue. The Haynes manual has the correct pressures and the procedures.
I spent ages trying to guess a problem where the car ran fine from cold and then just cut out / died when warmed up. Checking the fuel pressure identified that the warm up regulator was knackered (as was a second hand spare I got from somewhere else). Ended up getting a new Bosch one from GSF for about 130 quid which cured the problem.
Not sure if this is the issue with your car, but with hard to track down fuelling issues its always worth checking the correct pressure is being delivered to the injectors. If the readings are Ok at least you know its not that part of the system.
Good luck.
Chris
Life Member
he smuggles fags
dubboy said
I'm here and in France almost every week :wink:
…and I'm guessing that you'd be able to, like, do stuff to my car, so you do meet some of my criteria..
