my mk1 1.1...what engine to go for??
(In Topic #142406)
i have a 1.1 1982 tintop mk1,3 door..im thinking of going for a mk3 golf vr6 engine but not sure what it involves or a good thing to do,i have very little mechanical experierance but im definatly learning a lot from the golf
any advice would be appreciated!
Graham
Are you planning on doing the work yourself or getting a garage to do it??
If you have little mechanical experience you'll probably struggle.
Have a look at the engine conversion guides (link on the left side of the page) that'll give you some info on the most common conversions
Hope that helps!
Steff
I saw a crinkly peanut tomorrow
MissMk1 said
Hi Graham
Hope that helps!
Steff
The vr6 conversion requires alot of modification to the engine bay to make it fit. Also it's a very big heavy lump which hanging over the front end can cause some savage understeer.
You'd have much less hassle going down a small engine root. If you're fixated with the power coming from a the Vr6 you can get similar output from the 20vt aka 1.8 turbo conversion. This will also be alot easier to do to.
Shaney.
1983 Driver 1.3.
Build thread.
Build thread.
You will have to get your engine mount relocated to use a big block engine though.
do you mind if i ask,how much are you paying for conversion and who are you getting it done by?
Graham
abf and other big block 1.6-2.0 4 cyl engines require driver side mount bracket cutting off chassis leg and rewelding upside down in a different spot. vr6 requires a LOT of cutting and welding, not an easy job at all
1983 Driver 1.3.
Build thread.
Build thread.
Cheers!
1983 Driver 1.3.
Build thread.
Build thread.
