Golf Gti Questions
(In Topic #100995)
Golf Gti Questions
Anyways the car is a Gti Cab 1984 just a few questions really.
1. On idle when hot she seems to be ticking over at 1-1200 revs which seems a little high to me and also theres a slight miss, again only present when hot. Any ideas?
2. when driving some 50 miles back i noticed a light mechanical rattle whenever the throttle is depressed whether accelerating or at a constant speed. Seems top end and is not a heavy knock. I was thinking maybe pinking or tappets but again anyone had similar problems?
Apart from these 2 things at the moment nothing to report. Awesome car and cant stop smiling
Thanks in advance guys
Martyn
PS i a grease monkey by trade so any technical stuff SHOULDNT go straight over my head :p
If it has a slight misfire at hot idle, then you need to find why this is so - rich lean or ignition. I'd suspect ignition first, look at/clean up spark plugs, leads, dizzy cap, rotor arm, etc before replacing any parts. A wideband lambda probe would tell you straight away if its lean/rich or ignition related (they blip to high O2 if an ignition miss occurs). It could also be a poor spray pattern from the fuel injectors, but this would be the next thing to check out.
The light tapping - does it come and go with throttle application? If so its pinking. If its consistent or just gets louder/quieter with throttle, then its probably tappets.
martyn
mdaw_cab said
…………anyone reccomend any mods that are nice additions to a cabbie ……..
Solid roof? Sorry, just doing Wooders' job for him.
Martyn
Martyn
