FWD or RWD
(In Topic #81754)
FWD or RWD
Can someone please advise if the 1991 Gti Cabriolet was FWD or RWD also why is this important when buying new wheels ….
Thanks for any assistance provided
FWD, all golfs are except the 4WD ones
2 1983 Campains (concours & track)
1985 Blue GTi Ragtop
2001 Bora Estate TDi SE (very very rare)
2000 Golf TDI commuter
2005 T5 Transporter with 394000 miles on it!
Cant see it makes any difference when buying wheels? :dontknow:
Yep, I've got wider wheels on the back of my BMW and my 200SXcrazyquiff said
some peeps put wider wheels on the back of a RWD car
Thanks for the assistance I want 100 spoke wire rims
http://cgi.ebay.com/ebaymotors/15-Wire-Wheels-Spoke-Chrome-Rims-1-YR-WARRANTY-16_W0QQcmdZViewItemQQcategoryZ43955QQihZ011QQitemZ320025099154QQrdZ1QQsspagenameZWDVW
and
http://cgi.ebay.com/ebaymotors/15-FWD-Wire-Wheels-Front-Wheel-Drive-Rims-WARRANTY_W0QQcmdZViewItemQQcategoryZ43955QQihZ011QQitemZ320025112865QQrdZ1QQsspagenameZWDVW
the first is RWD the 2nd is FWD 15x7 4 lug
and
RWD cars typically have a lower offset, for example ford 7 spoke RS wheels made two identical looking types one for a sierra/capri and another for the s1 rs turbo if you put the wheels from a sierra onto an fwd escort they will stick right out.
Same as BMW wheels will fit on a Golf but again the offset if different.
If you check the offset and PCD you should be able to fit pretty much any 4 x 100 wheel, check carefully the clearance with the calipers and shocks though
could u define offset for me cos im daft, and i have beema wheels on!
chz
chz
rebuild in progress....
offset is the distance from the hub to the wheel face, I run BMW wheels on my S2 with no problem I think they are et 30 (offset ) where as normal GTI wheels are et38
Offset is the distance between the centre of the wheel, and its hub face. If its negative, it means that the centre line of the wheel is further inwards, than the hub.
should it say it on the wheel??
These are offset 40 will they not fit????
i had to trim down my rims alot.....
