Electrical circuit (blue)
(In Topic #155132)
I need new blue electrical circuit
I don't have a rhd circuit board, or an s1, but may be able to make a bridge.
If you want the PSD Boot Sticker file, it's here: Boot Sticker
What happened to the circuit? looks like it shorted out?
I have to come to Malaga a few times over the next few weeks, so may be able to tie-it up with something else.
I'm in Torrox.
Even if I can't get over there, I may be able to help you fix it yourself. I'm a mechanic by trade, although I fit 'Toldos' now.
If you fancy converting that to LHD, I have a couple of spare shells, and loads of bits etc.
The first thing to do is identify why it blew the circuit, and for that, it may be best to remove the circuit from the clocks and trace where each cable goes, then work out what wire has blown and where it went. If someone has a s1 wiring diagram for this part of the car, that would be helpful. Sounds like you may have a few wiring problems, although it could all be related. The fuse box isn't brilliant on the early models. What condition is yours in?
Longimanus said
I'll have a look where and when in my diary, had a quick look at your 'photobucket' pages, it looks like your doing a re-furb, so I'm guessing it's not going any where in a hurry?
I'm in Torrox.
The first thing to do is identify why it blew the circuit, and for that, it may be best to remove the circuit from the clocks and trace where each cable goes, then work out what wire has blown and where it went. If someone has a s1 wiring diagram for this part of the car, that would be helpful. Sounds like you may have a few wiring problems, although it could all be related. The fuse box isn't brilliant on the early models. What condition is yours in? I took mine compeletly apart and put it back together again after sanding down some electrical components.
