DP1- How cool is this?!
(In Topic #74318)
"Dennis Palatov started from scratch with a ?what if?? and his answer is the DP1, a Hayabusa powered track car with carbon fiber body and far too many technical features to mention. He is building this as a prototype for eventual production (projected February 2006) in several power variations, a stock Hayabusa engine, a turbo version and one to be powered by the Hayabusa V8 which we covered before and was developed by Radical Extreme sportscars. Performance should be ? quite acceptable.
His website documents the entire project from the initial sketches and proceeds step by step right up to the present very advanced state. If you want to see a project take shape, this is a great site."
http://www.dpcars.net/dp1/index.htm
One of the best websites I've visited - check out his project log - Nice :mrgreen:
I wonder what the lap time for the ring would be?????
And the cost………
dp1/s: $59K
Engine: Stock 1300cc Suzuki Hayabusa, 4cyl, 180hp.
Weight: 750lb. Power/weight 528 hp/ton (4.1 lb/hp)
dp1/t: $67K
Engine: Turbocharged 1300cc Suzuki Hayabusa, 4cyl, 265hp. Garrett GT28 ballbearing turbo 6psi
Weight: 775lb. Power/weight 752 hp/ton (2.9 lb/hp)
dp1/v: $85K
Engine: Custom 2600cc V8 based on two Suzuki Hayabusa motors on common crank, 360hp.
Weight: 850lb. Power/weight 931 hp/ton (2.4 lb/hp)
