Check your nuts boys! (and Girls!)
(In Topic #78021)
Life Member
Fortunately not too far from home so limped it back, with the rumbing noise getting worse rather quickly. Got to the driveway and had a poke around to find the front nearside wheel was almost ready to come free. :shock:
The bolts had slowly been working their way out and there was about 3mm of play between the wheel and the hub. Tightened everything up and we were all merry again, but I think I may replace the bolts forthwith, quite a few iron filings in evidence.
Never had that happen before, it never occured to me it might be something that simple. Bolts were all tight beforehand so I'm a bit bemused. :dontknow: Maybe my wife has checked the life insurance and is trying to murder me…
Cheers,
Drew.
Once a Mk1 fan, always a Mk1 Fan...
8O
Checked regularly now
(Same wheel :? )
Life Member
debs said
(Same wheel :? )
Now that is a bit spooky… 8O
Cheers,
Drew.
2nd time was after having new wishbone fitted at garage 3 miles from them and the wheel starts wobbling.. this time i just stopped as I knew what was coming. luckily i had the jack and bar ready in time. it appeared that in the first instance some one had loosened my bolts and 2nd time it was the garage not torqueing them up. So I always check them before setting off on long trips..
'83 Diamond Silver Campaign GTI
'85 UR quattro 20v 5 cylinder
'94 VR6 Corrado
'94 VR6 Corrado
1983 White cabriolet GTi
Mate lost a trailer wheel on motorway last year. Loads of people have lost trailer/caravan wheels. We decided it was;
they are never used or checked for long periods at a time
its difficult to tighten them as the wheel spins 'cause no weight in trailer or poor hand brakes
you don't get any warning that they are loose like you do on the car it self.
Another mate with a new caravan says that the garage selling them tighten the wheel nuts up infront of you and get you to sign a form to say that you are happy that they are OK! They must have had many come off before and don't want any more blame.
Glad all is well now though, sudden scary noises are rarely useful things….
Real golfers don't play with clubs
shouldn't have mentioned it on here though as some still mention it now
I'll be sure to ask if you've checked them at Gaydon drew
Felt it wobble a bit out back and slowly drove it home. Got the jack out the next morning and could actually pull the wheel off with the hub nut still in place! Bearing had completely disintegrated!
Close call…
My Build Thread
Scary though!
I had the same near side front wheel exactly as described, i noticed its when going round a mini roundabout. Stopped just in time to tighten the blots back up….
Could have been messy
Also, it makes them easier to open with a wheel brace.
You should drink more water.
1664 is 95% water.
Drink more beer?
1664 is 95% water.
Drink more beer?
