A Good Price??
(In Topic #78558)
A Good Price??
Hi Guys,
I have been quoted ?350 to Remove, Strip, Rebuild and Refit the engine in a MK1 1988 GTI is this a good price? I know it will be a good job because its a friend of the family
I have been quoted ?195 + VAT for the following parts from a local engine place to rebuild the engine with:
Head Bolts
Full Gasket Set
Mains Bearings??
Big Ends?
Piston Rings
thrus bearing?
Is this also a good price??
Sorry for all the questions
John
Head Bolts
Full Gasket Set
Mains Bearings??
Big Ends?
Piston Rings
thrus bearing?
John
Hi
sounds pretty good to me.
Ive been quoted ?215.00 to change the cambelt and check co2 etc from VW today. So i would say in comparison you have a pretty good deal.
Sounds about right for the labour ~14 hrs at ?20 per hour
Parts don't sound bad but you might consider:
Valve guides
Cam followers
Pistons
Oil pump
Oh and engine build/prelube
Might not be needed but you will not know until stripped and measured.
You ought to consider machining costs also:
Bore honing
Crank polishing/grinding
Head crack/pressure testing/Welding
Valve seat grinding
Balancing
And probably other stuff
Sorry, don't want to scare you but don't want your budget to run away with you
Valve guides
Cam followers
Pistons
Oil pump
Bore honing
Valve seat grinding
Balancing
