Which Exhaust
(In Topic #86043)
Which Exhaust
What would you recommend?
1967 VW Beetle
1967 Walkthrough Kombi
1983 Golf Driver - FOR SALE
not bothered if its stainless or not.
budget wise, if i have to spend money then i will
1967 VW Beetle
DubPartz
personally i like the jetex systems. mild steel and good quality. can't go wrong with magnex and supersprint, though the magnex is heavy and needs good rubbers to hold it up. scorpion, ashley and peco are loud. no experience of others that i can think of.
wooders said
ooh i like that. answers with no answers.
1967 VW Beetle
As the exhaust is going to be a larger bore it takes up more room as it threads its way over the torsion beam on the rear suspension. Then if your car has been lowered there'll be less room again and then if you have a couple of passengers in the back and a full tank of fuel expect the beam to bang the exhaust against the floorpan.
A good, well made exhaust should be designed with a 'flat' spot on the pipe that goes over the torsion beam. The Jetex does.
DubPartz
supersprint is standard bore size. magnex 2 1/4" jetex do 2" and 2 1/2"
Mk1 1983 Helios Blue GTI Engineering
Member 125 - 2005
