fuel pressure regulator
(In Topic #74700)
Right ive just tried to start my car for the first time in 5 days, and yes you guess it non starter after doing all the normal checks…..etc and giving the battery a full charge over night and putting a new set of plugs in still no go, since all of this i phoned a friend and he had me removing air filter box and pushing little flap inside….yea you guess it started which i was then told its the
can someone confirm this for me, before i start my search 8Ofuel pressure regulator
many thanks
mick
My view is if the flap is lifted and the car starts this indicated two things:
1. Cold start injector might not be firing causing a weak mix - the initial vacuum created is then not lifting the air flap which in turn meters fuel through the main injectors.
2. A major vacuum leak so that the flap is not lifted when the engine is cranked.
I would do the Cold start injector and Thermo time switch tests to very their operation.
If this checks out Ok then the system pressure checks need to be done to diagnose the problem.
Keep us posted
Rich
could you be so kind to tell me what ive got to do to test thoses???
thanks again
mick
If it does not squirt, squirts for only a couple of secs or squirts all the time then you neet to diagnose the fault whoich could be:
No squirt:
No power
Defective TTS
Defective CSI
Short Squirt:
Defective TTS
Always Squirt:
Defective TTS
Defective CSI
To diagnose you need to check 12v supply to CSI, TTS continuity and resistance.
Rich
Also before shelling out for a new reg, check the system pressures as Rich suggests and also make sure the fuel pump is delivering the quantity of fuel it should be.
If the fuel delivery test falls a bit short then your problem may be further back - filter on the fuel pump or gunk in the tank / partially blocked fuel lines.
Haynes has all the tests, but if you do decide to buy a replacement reg then the cheapest place I found was GSF as they required NO exchange unit and it was a genuine Bosch unit - about 150 quid all in I think about 2 months ago - pricey, but worth the peace of mind.
Good luck,
Chris
Right ive took out the injectors 1 at a time and cranked it over and there was no spray of petrol, now is this my problem the injectors are blocked and need a good clean or replacing or something else?, will the injectors still spray petrol while not correctly in place (aiming in a bottle) it seems odd that it started ok when i held open the little flap within the airbox with full throttle on
thanks again
mick
so make sure you have good pressure if not try a new fuel filter.
www.msportcam.co.uk
after realising i cannot just pull a injector out and crank it over to test sprays that way…..DoH i then moved onto testing other things, mainly fuel delively….etc with no joy.
Since testing all thoses things and putting the injectors back, i just told next to just pull the HT leads off and place them on the sparks plugs as this would make the car try just that little bit harder to get a spark :dontknow: the car started, so i put the HT lead back on, but still not running right, iam getting the odd popping/backfire when i try giving it a bit of gas, but its popping/backfire from airbox not from exhaust, so now going to try new HT leads today…fingers crossed :roll:
thanks
mick
Right ive just checked the Cold start injector and Thermo time switch and theres no power supply there :dontknow: not is there a fuse or a relay for thoses? or am i going to have to try rewire it?
thanks
mick
On an earler post you say it's backfiring through thr air filter, I was under the impression this is due to timing, firing at the wrong time which could mean the leads are on in the wrong order.
sorry no exact diagnosis but food for thought.
Rob
Audi A4 1.9TDI - Gone
