What shall I replace now?
(In Topic #80585)
checked injector's - about 4-5 months ago, not the best but don't leak
fuel pressure - drops intantly when the car is switched off.. right so:-
replaced the check valve in front of the fuel pump
tried a spare metering unit I've got (which, thanks to Rich I know it's good…. after killing his car
just swapped over the fuel accumilator… broke a fuel line so replaced the whole lot (thanks Rich again
Still losing pressure
so what's next?? it's not leaking anywhere
thinking start from the beginning, bite the bullet and replace the injectors + 5th injector as I can't think of anything else it could be
so chaps.. I don't want any comments when I go to leave Gaydon and it doesn't start! it's not like I haven't been trying
rebuild in progress....
I think it is probably leaky injectors with the petrol in the cylinder making the spark plug too wet to fire or something, until it is all pushed out of the exhaust… :dontknow:
My Build Thread
cabriaulait, my understanding of the WUR is that it wouldn't cause a loss of pressure if it was faulty.. but with the pressure tester's valve closed (which closes the fuel feed to the WUR) the pressure still drops
Al, sounds the same as mine, when hot, once it's started it runs like a bag of nails for the first 30 seconds (ish), few blips of the throttle clears it
thought the rough running when it starts was due to the pressure needing to build up enough to run all the injectors :dontknow: but I've replaced everything that's suppose to hold the pressure (check valve, metering unit's tested good, and the accumilator)
if it's no good once the injector's are replaced I'll leave it.. thinking about giving it the G60 treatment when it comes off the road again so it will go digipants
Life Member
as soon as I switch the engine off it drops to nothing, 10 seconds later the pressure 'blips' to about 20psi for under a second, then back to nothing
if that makes sense?
Life Member
Same here - a little help via the throttle seems to clear it quicker…PhillTMK1GTI said
Would make sense if yours ins't priming, though my pump is DIY wired through a switchable relay so I can leave the pump run for 5 to 10 secs before starting and I still get the same problem, which is why I am conviced that it is down to leaky injectors!PhillTMK1GTI said
Sorted out the oversize rings I needed for the valver now anyway, so that project is back on track, so hopefully all will be cured…by way of replacing the engine! :mrgreen:
My Build Thread
dubboy said
Where are you checking the pressure? I would start after the accumulator and work your way up until you find the leak.
checking it between the metering unit and WUR where haynes suggests
where else can it leak from as I've replaced all the fuel lines yesterday with Rich's lovely braided stuff
Al, you cheat!
one thing I did try is running the car with the 5th injector unplugged, made cold starting difficult and had no effect on hot starting
So the problem must be from the accumulator to the metering head then on to the injectors ………Ahhh its all pointing to those injectors then !
You have changed every thing else :dontknow: You might have to bite the bullet abd but some new ones . I did and mine runs lovely now .
Cheers………….
going to test them again anyway on the weekend, the spray pattern isn't the best but they're all within flow limits and didn't leak when I checked them last
won't be until spetember till I can buy new ones though :cry: she'll have to wait!
I'll dig this thread out when I replace them and let you all know
no leaks there at all :cry: and the spray pattern has improved since I last checked it 8O
the pressurised fuel is definately getting back to the fuel tank and after reading the Haynes manual again (almost know it word for word
it's either
Fuel pump check valve (replaced about a month ago - new VW)
Fuel accumulator (borrowed a used one.. possible they have the same fault I guess)
when doing the pressure test with the valve closed the pressure drops at the same speed
I'll bite the bullet and get a new accumulator and see if that sorts it (almost everything else is new now anyway
Any chance I could borrow one of your spare accumulators to see if they fix my problem?
Rich
got my number so give me a call any time after 7:20 :wink:
I'll give you a call then…
Cheers Phil
Rich
