weber carb question??
(In Topic #75521)
I do belive it was a Peirburg 2e2, Weber replacements was an upgrade me thinks. Most Carbs for the A1 was the variant of Solex/Peirburg.
I would like to know if the Cam is the same from a 1.8 8V GTi. From comon sence it probally was. Just a thought tho.
026109101G - I presume this the is the 1.8 Carb
049109101N - This is the GTi one
The 1.8 engine came in 66 (EX block), 77 (JH) and 82 (DX KT) Kw Versions
This info is from ETKA and ETOS and if anyone knows better please correct
:wink:
Now what i would like to do is just swap em over, is there any complications in this surgical procedure?. Waterways might play a part in this i thinks, but with any one with info? also head gasket, will i need the 1.6 head gasket or go for a new 1.8? i just hope its all going to fit like a glove, or am i going to sweat like micheal Jackson in a playground.
Your best bet is to source a 1.6/1.8L mechanical tappet camshaft, and wh
en fitted you should see about 8-10 bhp increase.
this is my 1st post,.
