Weber Carb Gaskets
(In Topic #156078)
Hi
Have take off my weber carb tonight to replace the rubber manifold mount, a couple of quick numpty questions.
Are the gaskets between the manifold mount and carb (square with four holes) available from places like GSF?
Shoud I use some kind of sealant gasket between the carb and mount and or mount and manifold? If so what sealant?
Thanks for any information.
Got my Weber gaskets from Webcon UK Ltd at Sunbury-on-Thames. Don't think we used any sealant. Hope this helps.
I've just done mine, was about £14 from GSF, very common fault according to the number they sell. Apparently the aftermarket part is one of the very few items that are better than OEM kit.
No sealant required, just clean the flat metal surfaces to get a good seal with the gasket bead within the new carb mount. 40 minute job.
