Vacuum Hoses - help please
(In Topic #86358)
Hi all, have a 1.8gti k-jet engine built from parts that I am tring to use and there are hoses missing which are part of the vacuum circuit from inlet manifold to air box etc. The Inlet manifold I have is one with the throttle body on the side of the cam belt (on the left) can anyone provide me with a circuit layout or possibly description or pics for vacuum hoses for engines with this type of IM. Most of the ones I can find seem to be the other way round. Really appreciate any help.
all mk1 gti's had throttle on gearbox side of block. if you want to put it on the otherside (cambelt) ???????? then you'll be better off looking at a mk2 gti layout.
Think your best using a mk1 inlet manifold and that inducts from n/s, otherwise your going to have to fit brackets etc for airbox and relocate washer bottle from O/S for no obvious benefit.
1983 1100 C
1983 1100 C
see if this helps..
I have a different vacuum line configuration (on a 1.8DX FI Cabrio GTI 1985) which I know is incorrect, and wonder if it makes the car's performance suffer.
The vacuum line to the distributor does not come from the nipple on the back of the throttle housing, which appears to have been blocked with something.
It comes from one of the nipples on the brake servo non-return value (the one which should feed the cold acceleration vacuum sensor, the other one is broken off with a screw stuffed in it UGH!)
Does anyone know whether not coming directly from the throttle housing would affect the sensitivity of the vacuum advance and therefore acceleration power.
Power develops rather slowly, although this could be just ignition timimg (set for 95 octane) or general old age (150k miles)
the vacuum to the distributor is required for advance /retard adjustment - the Germans didn't put this together for interest - they did it for very good reasons. i would suggest reverting to manufacturers spec
MP
MP
The set up on my car seem to be a bit different… I have the vacuum going to the distrbutor and the vaccum for the mfa, the other one next to the mfa was snapped off when I bought the car, and when the engine was running it was sucking in air. I taped that up. It is just a little slow on tick over now. Ive looked at other cars at shows and the one next to the mfa has a blank end. Are there different set ups? I'm confuesd!!!
83 Mars red GTI
01 V6 4Motion (daily driver)
09 Golf GTI MK6, candy white, superchipped!
No problem with going back to the correct configuration. Manufacturer's spec is always the best option. However I have to get the dammed plug out of the throttle housing. It may require drilling.
I was just interested to know whether a distributor advance/retard vacuum feed from the front of the inlet manifold ( i.e. the cold enrichment nipple on the non return valve) would make any difference from one taken the throttle housing. More or less sensitive to manifold pressure change for example.
If it made no difference, then I might not bother.
thats a really good question.
i think it could have an effect, tho i dont know why really, just strength of vacuum could be different. i think mines set up wrongly having looked at those pics, ill try it 2moro
rebuild in progress....
bump so i can find this easier
would dubdaves run differently due to the location of the dizzy advance vaccum ie not on the tb?
yep
i reckon!
yep
i reckon!
My clipper, is not idling or revving correctly! I have changed everything I can think of and now I am left with the vacuum hoses!! Can anyone suggest why between idle and 2500 rpm the car would be struggling?? It's fine when running cold but is very difficult to pull away once warmed up without stalling!!! Any help would be appreciated!!!
Those photos are a little confusing.
DX1.8gti
Vac pipe from throttle body goes to the distrib for retarding/advancing.
Vac pipe from 1 of the connections on top (by rocker cover) goes to the MFA.
if there is 2 connections (usually is) block it off.
this is how my setup is, and to be knowledge correct.
DX1.8gti
<a><img></a>
