Urgent help - fuel filter leaking
(In Topic #72746)
1983 1100 C
1983 1100 C
try them halfords must have some if not vw!
Simon
'83 Mars Red GTI
SIMAC - what do mean by Dowty ones? I have copper washers, but they also have smaller rubber O-rings that fit inside them. These look mangled assume these are needed to help prevent leaks under high pressure?
1983 1100 C
1983 1100 C
I think the idea of the copper washer is as it's softer than steel / aluminium, as you tighten the nut down, the copper deforms to form a really good joint.
The reason you have to renew them is once the copper has been moulded to fit the joint in the certain position, the chances are it will leak if removed and re-tightened as it won't be in the same position the second time round. Sometimes you can get away with it, sometimes you can't. As they only cost pence, it's best to renew them.
1983 White cabriolet GTi
1983 1100 C
1983 1100 C
1983 1100 C
1983 1100 C
Guest user
carlbeardsmore said
If you have got a blow lamp, just heat the washers up, then let them cool. This will make them soft again.
1983 1100 C
1983 1100 C
