twin carb fuel flow
(In Topic #81259)
twin carb fuel flow
is it possible to replace the fuel pump relay so as to prime the fuel system before starting , as the relay thats fitted now only starts when the motor is running or starting
thanks.
9A,027,278,02A,mikuni r1 carbs,megajolt 36-1,R1 pump,lc1,02J shifter,9J ats…
when you flick the ignition switch on you should get a short feed to pump to prime the system, or what you could do for the time being is fit a 1 way valve :wink:
