Sorry help needed again exhaust o2 sencor MOT
(In Topic #106120)
If that makes sence. I need to keep my o2 cencor of it will screw my ecu………………
So what do i do about it? Do i get my manifold and drill an oxygen censor hole? I just dont know
I just don't know can anyone offer any advice on it? DO i need a cat ect ect has anyone done it??
HELP!!!
:dontknow:
Help and advice always welcome
Regards Chris
:cheer: I've got my husband back :cheer:
If however you don't need a cat, then you still need to retain the O2 sensor. In this case, you'll need to have a bung welded into your manifold (its a standard size and easily obtainable); unless you can find a manifold with one in already.
Can I also buy a sports CAT?? or will the one i have be OK? or will it restrict??
Cheers Paul.c much appriciated
What my plan is, is just to forget the CAt for the time being when my MOT come arounf just buy one and weld it in but do i NEED one now?
ChrisRivage said
Ok if i have an o2 censor do i NEED a cat? will it effect it, it anyway?
I think you do, but the MoT regulations don't specifically say that a cat is a required item to be fitted. Basically, all they check for at MoT time is emissions, not the presence/absence of the cat. However since your car was fitted with one originally, the emissions levels required to pass are much tighter than for cars fitted without (and yes, they do check which cars were/weren't fitted with them) and for cat-equipped-originally vehicles, also include a lambda (mixture) check.
Unless you desparately lean out the engine, you'll have no chance passing the CO requirement. And they also check the lambda, which needs to be within certain limits, so they'll know that you've leaned it out to try get under the CO limit and fail it for being out of spec on lambda!
Maybe Bert or another MoT tester can clarify the situation though?
Like you said Paul not essential for me to have a CAT but i gotta pass my 02 censor test.
Ok this Lambda mixture test what exactly is that and how would removing the CAT affect that??
When was yours registered?
2 1983 Campains (concours & track)
1985 Blue GTi Ragtop
2001 Bora Estate TDi SE (very very rare)
2000 Golf TDI commuter
2005 T5 Transporter with 394000 miles on it!
juz said
The date of registration determins whether the car needs a CAT for an MOT.
In theory you don't need a cat for the MoT, just need to pass the emissions tests. But in practice, you can't pass them and have the car running normally, without the cat! I think the date is 31 Aug 1992.
emission's, always had to do that with my mate's that was
tuned
