Solved Cutting Out prob!
(In Topic #79764)
rebuild in progress....
cabriaulait said
… did the magnet thing pull up any debris, or did it just stick to the tank?
I had a go at cleaning my tank out with a telecopic magnet a few weeks ago - it seemed to work ok (I got quite a bit of rust out) but it did stick to the tank wall & inspection hole as I pulled it back out.
Still worth doing I would say along with a new fuel filter - once you have done the tank.
Black Cabbie
So how did you go about cleaning it out? Could you be sure that all the muck was out. I remember someone saying they found it impossible to get all the muck out and went and bought a new tank! I think I might need to do this job soon
Cheers,
Ross
2/ remove wheels
3/ remove top shox nut
4/ drop axle as low as possible
5/ unclip everything inc sender unit - making sure petrol dont get in your eyes or gob
6/unbolt tank with 5 bolts (2 front and 3 back)
7/ lift and lower tank over axle - mind those finger & lines tho!
8/ stand tank with filler neck lowest (need to plug this open -peg is good)and jet wash the tank through the sender unit hole, tapping outside with rubber mallet.
9/ repeat step 8 until water runs clear ( 5-6 times)
10/ put back together & fire-up ( will take some doing and WD40)
Ideally if your able to use an airline to blow water and leftover from tank and through the fuel lines.
Replace all filters including the one in the pump & uplifter.
if you dont know what your doing it'll take you 5-6hrs and Haynes, last nite it took me and a mate 3hrs - and an hour of that was flushing tank!
a simple effective job.
