Smelly
(In Topic #72147)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/IMG_20160516_173454.jpg)
![Dj Ev in the usergroup ‘Paid Member’ Dj Ev in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Dj Ev in the usergroup ‘Old timer’ Dj Ev in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Smelly
I know that you dont use a match before that suggestion comes in.
mk1 silver campaign totally standard lowered on coilovers magic tree vanilla
Just had a full outer body restore
![Avatar](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fwww.golfmk1.co.uk%2Fimages%2FExLink%2FAvatar.jpg)
![crazyquiff in the usergroup ‘Paid Member’ crazyquiff in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![crazyquiff in the usergroup ‘Paid Advertisers’ crazyquiff in the usergroup ‘Paid Advertisers’](https://vwgolfmk1.org.uk/themes/default/images_custom/PaidAdvertiserIcon.png)
![crazyquiff in the usergroup ‘Local hero’ crazyquiff in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
there is a number of places to check for fuel smells.
Check the seal around the sender unit on tp of the tank accessed through the plate under the rear seat.
Check the condition of the beather hoses and the trumpet type overflow at the back of the tank. This can drip fuel.
Check the condition of the braided hoses around the fuel pump and accumulator.
Check the condition of the fuel supply and return lines - corrosion is often a problem.
There are a number of posts around these subjects on the old forum.
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/20160605_084816191_iOS.jpg)
![Hairyarse in the usergroup ‘Moderators’ Hairyarse in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![Hairyarse in the usergroup ‘Paid Member’ Hairyarse in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Hairyarse in the usergroup ‘Regional Hosts’ Hairyarse in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![Hairyarse in the usergroup ‘Local hero’ Hairyarse in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
I used to have a fuel smell when driving and when brimming tank completely full, petrol would drip on the floor under the back of the car for 20 mins or so.
Cut a long story short, turned out to be the O-ring under the fuel tank sender unit had gone. Replacing this sorted all the problems - both leak and smell!
![lhasa in the usergroup ‘Old timer’ lhasa in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![m6m62 in the usergroup ‘Old timer’ m6m62 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
If you mean in front of the passenger door (ie, bulkhead area) then it could be the end section of a fuel line. Could be a flexi hose or a loose union (doubt the latter though).
No way should you solder a fuel (or brake) line. A quick way to set fire to your car !!!
If it's a brake line then replacing it is an easy job. Replacing a fuel line is a lot of work. You may be able to cut the old line below the leak (with tube cutter), and splice in a new section of tubing using brass unions and a pipe flaring kit though.
Good luck with it………
Mark
The pipe is underneath the drivers floor pan, the one nearest the door. I think I will try and put in a piece. What size pipe do you need and where can I get it from?
Cheers,
Mark.
