SETTING THE TIMING
(In Topic #79804)
SETTING THE TIMING
1983 VW golf mk1 1.6 dsl.
1987 VW caddy mk1 1.6 dsl.
1986 VW caddy mk1 1.6 dsl.
1989 Jaguar sovereign 3.6 auto
1978 Mini clubman 998cc
1972 Mini 850cc
1989 volvo 340gl 1.7- sold
1989 Mitsubishi shogun 2.5 tdi
1972 Mini 850cc
The cam timing is a turd,remove the rocker cover and you will see a flat groove in the rear of the cam,slide a flat piece of steel into the slot and it should sit level with the cylinder head,the cam wheel needs to be loosened and tapped off its taper so it will rotate,this will enable the belt to be set properly.
the fuel pump has a v groove in the casing,line it up with the groove on the carrier plate,the pulley also has a groove and this is the timing mark,they should all line up.
The belt should be fitted and tensioned, then lock the cam wheel up,check crank is spot on,fuel pump is lined up.
the pump cant accuratly be timed up without a dial guage screwed into the rear of the pump
but it should run at that 8O
bert
